RE: Building Question
Well the Slow Stick has a motor with it already. Anyway a 380 motor is too big and too heavy. Also you couldn't use that receiver or servos either. The Slow Stick requires all micro equipment. To answer your question, the things you have will not work on this plane. But if you do want the Slow Stick, you would need a GWS Flight Pack. It runs about $75. This pack contains a micro receiver, micro esc, two micro servos and a 7.2 6 cell battery. And you will need to get a micro crystal which is not included in this pack costs about $10. The micro crystal can be ordered by any hobby store. Be sure to get the GWS Flight Pack that works with your type of radio and the channel number for the micro crystal.
