RCU Forums - View Single Post - Aerohawk sliding -
Old 04-04-2004 | 05:11 PM
BENZITO
Default RE: Aerohawk sliding -
When you do lift off which direction does the heli go? It should be in a neutral position and not favor any direction unless your linkages or trim are not setup correctly , 75% throttle should send it straight up then observe where "it" wants to go then correct it by either trimming the controller or the servo linkage .
