arerobird trimming
When I fly my aerobird at full throttle it wants to climb all the time, I can reduce it to half throttle and then use the trims on the transmitter to achieve level flight, but when I want more power it just climbs. Is there any way to trim the plane up without using the elevator all the time to achieve level flight..or is this normal, I mean once you've got the plane in the air and cruising and you give it full throttle are you then supposed to control it with down elevator inputs to keep its nose level. Its just that when I read some of the threads they say ' I tossed her in the air and trimmed her up and was flying hands off straight and level' do they mean at full throttle if they do then I am doing something wrong ! If you do control the plane at full throttle with the stick then thats fine, because that's what I'm doing now, but it just seems a little clumsy...Hope you followed that..any idea's
Cheers
