RE: Please help!?
they are not the same, the duratrax air oil is for your air filter while the after burn oil goes in your engine, as an after-run oil to keep parts lubricated
regards
phil
**edit...since they are both oils you may be able to get away with using them interchangably in the engine compartment. im not sure on that though. might as well be safe and get the after burn oil and use that in your engine
