RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
Please help!?
Old 04-05-2004 | 10:51 PM
Mxracer45's Avatar
Default Please help!?
Is this http://www2.towerhobbies.com/cgi-bin...?&I=LXZH53&P=7 and this http://www2.towerhobbies.com/cgi-bin...?&I=LXVH20&P=7 the same? or do each have their different purposes
Old 04-06-2004 | 12:32 AM
Default RE: Please help!?
they are not the same, the duratrax air oil is for your air filter while the after burn oil goes in your engine, as an after-run oil to keep parts lubricated
regards
phil
**edit...since they are both oils you may be able to get away with using them interchangably in the engine compartment. im not sure on that though. might as well be safe and get the after burn oil and use that in your engine
Old 04-06-2004 | 09:53 AM
Mxracer45's Avatar
Ok thnx!
