ORIGINAL: TyBryner
Please elaborate. Was it easier to use?
Yeah it was much easier to use. I've used MK on 3 planes now. In every one there have been wrinkles. You can't get those out if you are using MK. I also have a Sig SE that was covered using MK and the turtle deck looks like crap b/c the MK didn't shrink well. With UC you iron the edges down at about 220 - 250 degrees and then take a heat gun and shrink it. Any wrinkles shrink out even the ones where the covering is stuck to itself. The turtle deck was SOO MUCH easier to cover with UC also. Just seal the sided, front and back with the iron then let the heat gun do the rest. Only complaint I have about UC is they don't have maroon color. Since I goto Mississippi State (maroon and white) it's pretty much an essential.
