RCU Forums - View Single Post - Bubbles in fuel line
Old 04-07-2004 | 11:55 AM
FLYBOY's Avatar
FLYBOY
Default RE: Bubbles in fuel line
ORIGINAL: ED STEFAN
WHOA! I posted too quick. According to the pic at post 6, this is a carb needle, not a remote.
Still good advise for remote needles though.
Oppps, I should have blown up the picture. Looked like a remote when I looked at it. The third line you have looked like a line to a remote needle.
That changes things. The bubbles in the line have to be coming from the tank then. Sorry about that.
Make sure your tank is not jammed in the fuse too hard with foam. If it is mounted too solid, it will produce the bubbles you are seeing. I have a friend that had too much foam around it and it was too tight. That was the same as not having any foam. Huge bubble problem. Check that out.
