RCU Forums - View Single Post - H9 Funtana problem with elevator joiner flexing
Old 04-07-2004 | 09:25 PM
Dany boy
Default H9 Funtana problem with elevator joiner flexing
The stock joiner wire for the elevator is flexing under low load causing the left elevator half less movement which causes the plane to roll when pulling on the elevator...
How to fix this problem? I don't want to install two servos (one for each side of the elevator)
I thought of installing the servo in the fuse, and drive a "Y" shaped pushrod going to each elevator halves?? Is this a suitable solution?
Help me guys, I in the process of aseembling it with a Saito 91....with standard servos using most of the stock hardware..
In addition, how to beef up the landing gear and firewall, I can add peice of wood and epoxy all over the place but I am looking for the lightest solution with maximum strengh.
