RCU Forums - View Single Post - Aileron Servo
Old 04-09-2004 | 03:07 PM
Montague
Default RE: Aileron Servo
If your ailerons use torque rods (which most trainers do), you can also get the effect (aileron differntial) by bending the torque rod arms forwards slightly and shortening the pushrods to match. You can also just shorten the pushrods a little, which as the effect of moving the arms forwards and reflexing the ailerons a little bit.
