RCU Forums - View Single Post - Can I convert this Ryobi?
Thread
04-10-2004 | 09:23 PM
9
Edwin
My Feedback: (
2
Feb 2002
6,204
1 Post
Leander, TX
RE: Can I convert this Ryobi?
Purple,
I modified the bandito grande a lot to handle a gas engine. Sheeted the aft control surfaces with 1/16" balsa and mounted the servos in the back. The bandito builds very light and is a frame structure behind the wing trailing edge. I sheeted the inside of the frame with 1/8" balsa on the inside of the frame work so there wouldnt be any outside contour problems. I moved the firewall back 3 1/4" and made it out of 3/8" ply. I balanced with no led at all. Also moved the canopy back one fuse former and lowered the profile for a more streamlined look. I made a fiberglass cowl sorta P-51 style. The flaps and ailerons were increased in size to 2 1/2" wide. With all those mods, its ready to fly dry weight is 13 lbs 14.5 ozs. Attached is my stock built Bandito Grande and my modfied version. It flys great.
Edwin
Reply
Like
Edwin
View Public Profile
Find More Posts by Edwin
View iTrader Profile
