RCU Forums - View Single Post - sig four star 60 question
Old 04-11-2004 | 09:02 AM
DTB's Avatar
DTB
My Feedback: (15)
Default RE: sig four star 60 question
ORIGINAL: FrankEscalle
Also where did you put that fuel tank hatch
Sorry for the delay FrankEscalle. The hatch is under the fuel tank. That area is perfect for battery placement and creating a hatch makes it easier to get to. You can also use it to add lead weights if you need. You can see where I had some, but removed them later once I started adjusting the CG. Just make sure that you epoxy or use CG to seal the wood inside the compartment. This should be done anyway even if your don't make a hatch. Hatch just makes it easier. You can see how it is held in place with four small screws. Pictures can say a 1000 words.
I have attached some photos of my hatch. Let me know if you need any more photos or anything.
ID:	120982   Click image for larger version
ID:	120983   Click image for larger version
ID:	120984   Click image for larger version
