RCU Forums - View Single Post - Can I convert this Ryobi?
Old 04-11-2004 | 09:22 AM
ZAGNUT's Avatar
ZAGNUT
Default RE: Can I convert this Ryobi?
just checked out the wacker site and the ryobi parts are a good deal...but then some of us still like doing it the hard way
if your engine is the long shaft version then the hub is simply a spacer...a stack of washers would do just fine. mikenlapaz even made a hub from plastic[8D]
the mount is just a piece of rectangular aluminium tubing...all you really need is a drill, a hacksaw and file[8D] you can also just use long backplate bolts with drilled dowels or metal tubes as stand-offs
either way you will have fun
dave
