Piccolo board on aerohawk problem
I just purchased a GWPHA01 3 in1 from Helihobby.com for my areo hawk, the problem I am having is that I set all the transmitter controls and trims (centered) to the required settings, I turn on the transmitter and plug the heli battery in, the second the LED comes on the tail rotor motor starts spinning even if I set the tail rotor trim all the way off it still starts immediatley I tried turning the mixer all the way off and it still does it. So it is always turning the tail unless I have trim set all the way to off and add some stick to it. I have emailed Helihobby.com 4 times and called once but it said their mail box was full so I couldn't leave a message and have not had a reply yet (been trying for 3 weeks) Has anybody else had this communication problem with helihobby.com. Since they won't help me is there anything else I can try. I have checked out the transmitter and it is ok, have tried a new tail motor, the problem does not stop. I believe the problem is in the board ?, has anyone else had this problem. Any feed back greatly appreciated
Thanks Gyroguy
