RCU Forums - View Single Post - ExtremeflightRC Mini3D conversion
Old 04-12-2004 | 11:31 AM
Mike Parsons's Avatar
Mike Parsons
Default RE: ExtremeflightRC Mini3D conversion
Hey Kirby,
Yes I flew it quite a bit. I ripped the gear out due to my field being too rough and havent found a good way to put it back yet. The performance is good on the 11x5.5, but I seriously recommend the 12X6 E on a pack that can handle up to 40a. My 3S2P TP's would only handle about 32 amps, so I couldnt push them that hard. On a 12X6 you will be about 36 amps and it will pull out of a hover easily. The 11X5.5 would pull out, but at a slow walking pace. I am trying to have some CF gear made for it so I can retrofit it inside the fuse. Otherwise, I will have to pick up a new one and convert it before SEFF.
-Mike
