ExtremeflightRC Mini3D conversion
FL
mike
I glued the magnets back in on my AXI282010 and it works some. It jitters and then stops at full throttle. There seems to be resistance that was not there before. I am thinking the epoxy I used was put on to thick. Suggestions
#31
ON, CANADA
i really love this plane and am wondering where this plane hovers at wiht this axi, also how do you think a apongee 3s2p 4100mah lipo would do?
#33
FL
Chris
Mike will have to answer you question. Mine M3D crashed after 3 short flights. I didn't have the elevator servo secured good enough to handle my son's aggressiveness. Also I used 10 NIMH Hecells.
#34
Sorry for the late reply:
It will hover just above half throttle. The Apogees will do fine and will give you more headroom to get the amps in the high 20's to low 30's by swinging a larger prop. I would use a Pheonix 35 or Pheonix 45 (www.castlecreations.com) with this application. The 35 is as low as I would go however.
Stephen,
Glad HL got you fixed up.
-Mike
Stephen,
-Mike
#35
ON, CANADA
That was actuially quick reply
thanks for the info I believe those apongees can handle 44amps constant, anyways I was looking at the esc's yesterday in a Hobby-shops catalogue and the Jeti esc's apealed to me not to sure why but they seemed like good ones but i noticed they had one with BEC and one without (both advanced 40 amp ones) the one wiht could handle up to 12 cells (3 lipo) the one wihtout could handle 16 cells (5cell lipo?) what is BEC i like the one with the 16 cells range as i could use it on another convertion that needs maybe one or 2 more cells.
#36
ORIGINAL: JuniorPilot
-Mike
#38
I do suggest buying an OPTO version on anything over ~30 amps. However, I would use a UBEC in place of the RX pack. You can just see the UBEC in my first post as it sits just above the RX (white shrink wrap). You can probably get away with using a BEC version, but it is just on the outer limits of the BEC rating. That is another reason why I like Castlecreations Pheonix controllers. You have the option of using the BEC or disabling it by pulling the center (red) pin out of the plug.
-Mike
-Mike
#39
ON, CANADA
ok thanks do you maybe have a picture of how the UBEC fits into everything (the circuit how it's connected) because i saw the little drawing on the site but don;t really understand it
#40
Plug from the UBEC goes into any unused slot on your RX and of course the ESC plug goes into your throttle slot on the RX.
#41
ON, CANADA
ahh thanks for all teh help hopefully i will get to do this convertion for next season i am in teh mids of getting a job (only 15)
#42
FL
Mike and jp
I am looking at rebuilding the fuse of my M3D and equiping it with a geared speed 550/600. If that will fly my EMagic, it will fly this one even better. I'm very busy at work now, OT everyweek, it my take some time.
Mike
I got my new replacement AXI from HL. They really stand behind their product.
Mike
#43
ORIGINAL: StephenT
Mike
Mike
Mike
