RE: Control Setup Question......
[8D]sounds as if your cg is a tab to far back. Before adding weight. Check your cg, if more is need up front, move something. (anything before adding lead). You may even go to a heaver spinner. The expo will help alot, but only if your not to tail heavy. astro
