WACO
Kevin
What is the CG location on your interceptor?. I will test fly my new one tomorrow and I want to compare notes. I have Marty's turbine wing configuration just like yours. Power is a RAM-750 with Tam's pipe, BVM bypass. Dry weight is 12.5lb in primer. I'm using the crow wing configuration as you recommended few years ago. I flew my last DF setup that way and it really helps it during landing.
Thanks in advance for your prompt response.
