ORIGINAL: basmntdweller
I have mine setup with proportional travel throughout the elevator travel. I may not use full aileron travel in flaperon mode but full up elevator gets the same amount of down aileron as full down elevator gives to up aileron. Clear as mud huh! basmntdweller
I think what you are saying is that you have the ailerons linked to the elevator. The aileron servos are set with exponential travel and only go to say 50% of the total aileron servo deflection as an endpoint. As opposed to the elevator servos that go to 100% deflection linked or unlinked. You have the rate and amount of travel equal for either direction of the aileron servo.
