RCU Forums - View Single Post - Mixing down elevator with brake servo?
Old 06-23-2002 | 03:30 PM
lov2flyrc's Avatar
lov2flyrc
My Feedback: (24)
Default Mixing down elevator with brake servo?
Sent you mail!
Figured I would put it here as well...
Hey Anurag,
Here is my setup....
On Mix1:
MAS: ELEV
SLV: AUX1
LINK: OFF
TRIM: OFF
SW: E (Set to switch E (retracts) so brake application with elevator shuts off when gear is up to save air)
POSI: UP
RATE: down=0% up=100%
OFFSET = 100%
You will also need to go to AUX-CH menu and set CH7 to VR-E which will place brake control on right slider as well.
I also mixed my speedbrake so it would retract at 65% throttle stick, one less thing to have to think about if a go-around is initiated. Here is how...
MAS: AUX2 (Speed brake channel)
SLV: AUX2
LINK: OFF
SW: STK-THR
POSI: move throttle to desired retract position (50+ %) and press jog dial for 1 sec, percent wanted will be inserted. if wrong percent is entered then just move stick higher or lower and hold jog dial again.
Let me know if you have any further questions....
Best Regards,
Todd
PS....are you getting close to flying???
Back to work on the BobCat.....
