RCU Forums - View Single Post - Must Haves For Kit Building?
Old 04-14-2004 | 07:14 AM
zetor
Default RE: Must Haves For Kit Building?
I just built that same kit. It was a lot easier than I thought it was. The only thing I bought that I didn't already have was a slab of pink foam insulation and a damaged door at home depot. I don't really think you will need much more than the common tools required to assemble an arf. I had a bunch of t pins already and ca. A fine toothed saw would probably come in handy and a t bar sander with a few rolls of sandpaper of varying grits. It is easy and can be built in a week. Covering was the hardest part for me. Getting glued on plans off my fuselage was a bit tricky too because I forgot to put wax paper down a couple of times.
