RCU Forums - View Single Post - Should I remove my pants?
Old 04-14-2004 | 05:49 PM
3D Joy's Avatar
3D Joy
Default RE: Should I remove my pants?
Wheelpants are things designed to be removed on the third flight...
I will not use wheelpants again, they are hard to maintain and can cause the plane to nose over if any problem happens, from the little rock that gets stuck between the wheel and wheelpant to the wheelpant getting loose so that it flips and you actually land on it...
No wheelpants are lighter, cheaper, and easier on the nerves.
I feel better now.
