RCU Forums - View Single Post - Sukhoi 26 - need data!
Old 04-14-2004 | 08:03 PM
rmm
Default RE: Sukhoi 26 - need data!
Here are some pics:
As you can see, I doubled /enforced the side of the fuselage in order to distribute the forcs. In the previous tank area I also inserted some plywood in order to absorb as much as possible. The entire part is covered with fiber glas and that's abot it. So far no problems - however, I did not have a rough landing yet.
I hope this will help you & good luck!
Regards
Rainer
ID:	122374   Click image for larger version
ID:	122375   Click image for larger version
