RCU Forums - View Single Post - LANIER EDGE 1.20 CG PROBLEM
Old 04-16-2004 | 10:13 AM
Liv2Fly's Avatar
Liv2Fly
Default RE: LANIER EDGE 1.20 CG PROBLEM
This ARF does build tail heavy due to the increased length, almost 1.5" in the rear turtle deck area as compared to other manufacturers planes. When you look at the overall length of the plane it almost resembles a pattern plane from the cockpit back.
I am adding some additional pics of the fuselage wing bolts that were added. I simply went to the hardware store and purchased some toilet seat bolts and cut the heads off, then mark and drill your holes in the fuselage, next glue/epoxy the bolts to the wing. I would also like to encourage other builders to show their tips for better building solutions. Also, please show us any other photos of the Lanier Edge 540T build.
THANX,
Jeff
ID:	122876   Click image for larger version
ID:	122877   Click image for larger version
ID:	122878   Click image for larger version
