RCU Forums - View Single Post - Hangar 9 Twist 3D
Old 04-17-2004 | 12:09 AM
  #34
Cornduster04's Avatar
Cornduster04
Default RE: Hangar 9 Twist 3D
The Tail wheel bracket I buy from LHS is from Sullivan. Mounts on the bottom of the fuse and then has a spring that is attached
to the underside of the rudder.
There is also a spring on the wheel bracket for absorbing those bumps if you need to.
I usually put a small piece of plywood on the bottom of the fuse before I mount the tail wheel bracket. I like this
set up because if it bends I can take it off and straighten it out easily or replace it. Costs about 6 bucks.
I will be happy to send you a pic when I get it mounted. Working on the elevators right now.
I am a slow builder, 4 hours into this and don't have the rudder or elevators mounted yet. I did have to make
the servo holes bigger so that took some time.
Cheers!
