RCU Forums - View Single Post - Question about position of switches?
Old 04-17-2004 | 08:53 AM
SAL98's Avatar
SAL98
Default RE: Question about position of switches?
Thanks but I don't have a problem drilling the backplate. My ZDZ came with a prop drill jig thats made up the exact same way. It has a 1 inch thick hub made of steel, and a 10mm bolt with nut and washers to connect to the prop or backplate.
Easy to drill by hand but I guess I am just being lazy. I figured if i had to order a new spinner to fit a menz prop, why not have it drilled as well.
Also i thought that the backplate didn't have the 10mm hole drilled in it yet and I know if you don't drill this straight you will throw off the balance.
