RCU Forums - View Single Post - Hangar 9 Twist 3D
Old 04-17-2004 | 12:02 PM
  #37
suitcase's Avatar
suitcase
Default RE: Hangar 9 Twist 3D
I got to work on mine again last night. Got the ailerons mounted along with the horns. All I need to do now is drill and mount the servos and the wing is done. RVator advised me to dry fit the aileron servos, line up the horns and mark for the horns before actually glueing the ailerons on. That way you can lay the aileron flat on the table to install the horn screw. They're hard to get in once it's on the plane. I did it that way and it was better. Plus drilling the marked holes with a small drill press assured the holes were straight. I too had to enlarge the servo holes just a tiny bit. I'm hoping to get mine ready for next week end. May have to use the OS 46FX.
