Model Tech Magic ARF
One thing you will have to watch out for aswell is the landing gear setup. The Magic is a taildragger, which means there is no nosewheel, and the main landing gear is moved forward some. This will make takeoffs and landings a little trickier, but if you've mastered the trainer you should be good to go after you do what FH said.
