RE: Changing Original Transmiter to a different one
The Alpha trainer (if i remember correctly) comes with a radio that is essentially EQUAL to the Futaba SkySport... not junky. Not worthwhile replacing it.
I'll look it up and double-check. But if I'm right you'd be wasting your time.
Specifications
Assembly Time: Less than 1 hour
Wingspan: 63 in (1600 mm)
Wing Area: 710 sq in (45.8 sq dm)
Length: 52.5 in (1334 mm)
Weight: 5.25 lbs (2.4 kg)
Radio: JR Quattro (installed)
Engine: Evolution Trainer Power System (installed)
The JR Quatro is a direct competitor with the Futaba 4 YF. they are EQUAL quality. You would be wasting your money replacing that wit the Futaba radio.
BOTH JR and FUtaba make good stuff.
