RE: Hype 3D
the Hype is a good quality kit, with everything you need except radio, engine and prop. The accessories are of acceptable quality, although I replaced my elevator clevices for metal ones.
the .46 on a purple pipe will have enough power to hover it, however the throttle response might be a bit on/off with the pipe which can be a bit of a pain for 3D.
IF you can afford it get the weston 50T, otherwise consider the new Just Engines .56 with a throttle pipe
If you are going to use standard servos use a 5 cell battery for a bit of extra torque and speed.
its an ideal model to learn 3D
