RCU Forums - View Single Post - Need hull help
Old 04-18-2004 | 08:31 PM
petry75
Default RE: Need hull help
What my plan is, is to take my o.s. engine, fuel tank, reciever, and servos out of my 42" jet stream 1000 and put them in a different hull. I decided that I would like trying to build one because I don't like the abs plastic hull of the jet stream, and I don't like the outdrive rudder on it. The plastic rudder melts where the rudder shaft runs through it.I have replaced the bushings with bearings, and did tons of adjustments to it, But it keeps melting it. Once it melts the rudder shaft vibrates which has caused lots of problems. This boat also doesn't turn right very well.
Pete
