Need hull help
I am building my first hull ( deep vee ) . I have an O.S .32 SXMX engine. I don't know the max. weight my hull could weigh to make it go around 30 mph. If anybody could help me with this one I would appreciate your response.
Thanks.
Pete
Thanks.
Pete
Hi Pete,
What size is the hull you're building?
In general a deep vee should be as light as possible, my scratch built shallow V hull (110 cm) weighs just under 900 grammes, it has not been covered in glass and epoxy resin yet.
Greetings, Jan.
Greetings, Jan.
Go with a hull at or around 30". This motor is not a powerhouse but 30 MPH should be no trouble. Look for a lightweight .21 hull.
Alright, another Michigan boater! I've never been that far North but have heard of that City for the huge car show that you have up there every year.
Thanks for the info.
You got the right city for the crazy auto show Ron. It's so big it's out of control.
for my hull-the info really helps because I didn't want to go below 30". I have a friend helping me with this--I'm not very good with fiberglass so it should be a learning experience.
If you want to go scratch built or from plans, try out the Wild Thing from www.rcstore.com .
I'm South of you a ways, down in Kalamazoo, home of the NSRA Street Rod Nationals North for many years now so I know what it's kind of like. One of the biggest gathering of Rods short of the Nationals, averaging over 3,400 a year.
What my plan is, is to take my o.s. engine, fuel tank, reciever, and servos out of my 42" jet stream 1000 and put them in a different hull. I decided that I would like trying to build one because I don't like the abs plastic hull of the jet stream, and I don't like the outdrive rudder on it. The plastic rudder melts where the rudder shaft runs through it.I have replaced the bushings with bearings, and did tons of adjustments to it, But it keeps melting it. Once it melts the rudder shaft vibrates which has caused lots of problems. This boat also doesn't turn right very well.
Pete
Pete
If you want some extra strenght, add a light layer of glass silk, or if your hull has no concave surfaces, cover it with a panty hose and epoxy it.
Greetings, Jan.
Greetings, Jan.
