RE: SIG Rascal Forty in the house!
KMOT . looks good what you have there . it will help a lot . i also added a 1/8 ply 5 1/2" 3 14" to outside under the belly of the plane covering the landing aera . the ply extends 3 "ahead of the bolt holes . this gives you even more beef. put covering on one side be-for you epoxie it on .you need clamps to hold the ply . it has to bend to conform to the bottem. PS throw that sig tail wheel . replace it with a sullivan tail wheel . those springs for stearing arn't to good . with the sig wheel the plane is real squirrely on take-off un till you get the tial up off the ground. GOOD LUCK YOU WILL LIKE THIS PLANE flys fast needs a lot of runway for landing . it's a floater . BILL WRC-FLYER
