RCU Forums - View Single Post - Evader Differential adjustment?
Old 04-19-2004 | 12:06 PM
jaywebguy's Avatar
jaywebguy
Default Evader Differential adjustment?
What is the purpose of the differential adjustment screw? What will happen if it is too loose, or too tight? Do you adjust it differently for different types of surfaces, ie. hard packed dirt vs loose gravel?
The book tells you how to adjust it, but doesn't specify why, other then to say if it's not done right, you risk the chance for your car to break?
Thanks.
Jason
