RCU Forums - View Single Post - Evader Differential adjustment?
Old 04-19-2004 | 01:37 PM
Mastec's Avatar
Mastec
Default RE: Evader Differential adjustment?
My brother discovered if its too loose the truck will go no where. It is used to adjust for different surface conditions. The way I learned years ago was to hold the right rear tire in your right hand. Hold the spur gear with your index finger so it does not move. Then try to turn the left rear wheel. If it turns easily then the diff is loose. Keep adjusting the diff until it is impossible to turn the left wheel.
