RE: CA Model Eclipse building tips
I put on 3 more flights this weekend. Looks like the cg is a little forward. I have it at 6 5/8" from the leading edge measured at the root, and I need up elev trim for level flt (4 clicks). That also causes it to pull to canopy on vertical down lines. Question for Steve: Where are you flying your cg? Thanks
