RE: Help with real flight G2
What computer system are you running? Is it the G2 USB version? It sounds very similar to problem that I had while setting up G2. I was using windows98 and if you are as well let me know. If you are then the problem could revolve around the USB plugs in your computer. Real flight is picky and only seems to like the later USB port versions. Its certainly not a Directx prob.
