1- THE HOZ. STAB IS TWO PC. ON CARBON TUBES THE STAB FITS THE TUBES AND THE FUSE FINE BUT HAS 1/4" SWEEP BACK.
It is supposed to be like that.
2- THE WING JOINER IS 4 - 1/8" PLYWOOD PLATES LAMINATED TO FORM ONE (NORMAL) BUT THE JOINER IS 4" TO LONG, THE SOCKETS IN THE WINGS ARE 2" TO SHALLOW TO EXCEPT THE JOINER.
They aren't too shallow. the piece of wood blocking you is a bit of balsa former in the way. You can break through it with a long screwdriver.
3- THE PLASTIC COCKPIT IS AT BEST HALF @$$ED GLUED ON.
Mine was exactly like yours. Had to reglue it on
4- THE BELLY PAN ON MINE IS CUT TO DEEP AT THE BACK AND FITS VERY POOR.
Trim the b/p at the from with a dremel tool to make it fit smoothly.
5- THE PAINT ON COWL IS DRY AND FULL OF FISH EYES (RED ONLY)
Never had this problem. Ask ace for a replacement
Dieter
