RE: YS 120 Prop throwing problem
Tande,
I set the high speed needle full closed then backed it out 2 full turns + a couple of clicks to be sure not to run it lean. This is what the instructions said to do.
Could I have the low-speed adjustment (regulator) to lean since I an starting it with the throttle just cracked open?
