RCU Forums - View Single Post - The Twist Rocks!!!!
Old 04-23-2004 | 11:29 PM
3DWANT2B
Default RE: The Twist Rocks!!!!
P-51 Not sure on the 12.25 prop but I did have to trim approx. 1/8" from the hub on both leading and trailing edges. That is for a APC 11x5 prop, so I'm assuming you might need even more for your prop. I'm wondering if a 2 3/4 spinner would come with larger openings.
