RE: Full Brushless (100%) Dragonfly - Version 1.0
Hi Mugga
I not sure what is the gauge of the wire. I got nothing to measure it. To compare, it is about double the thickness of CN12-RXC wire. I tried using CN12-RXC wire and I can turn 19 rounds per pole but the speed is too slow (Remember I only use stock magnet). So, I use wire that is about double the thickness (From some transformer) and due to that, I can turn up to 10 Turns. Anything higher than that will have difficulty of winding the next pole or having problem putting back the magnet cap.
I'm being using Raised Tail Boom since Feb 2004 I think. So far so good. At least I do not required Tail Skids.
BTW...That Raised Tail Boom odd cutting is previously for CN12-RXC motor. That is why u see a funny/odd cut out for the Brushless motor shaft.
Super-Hornet
