Some Final Configuration Q's
I adjusted the swash arms and now I have 40, 60, 80% corresponding to -2, +5, +11. Does this sound correct ? If so, should I decrease the end points for ail., pitch., & elev. to fill out the range ? The center swash is now +1.5 degrees. I know you should it should be 0 but I the illustrations indicated a range of -10 to +13. AFR is now +50, +50, -50.
