eclipse and negative shift
There's no problem with the Eclipse negative shift function. It is most likely the feather Rx. Are you using the Single conversion crystal, part number 66472XX? Do you have any other negative shift Tx's, do the feathers work with them?
If you wish to have the feathers checked out, Hitec will do it for free.
