RE: ESM 57' extra
Build is comming along nicely,but the cut outs at the tail for the stab needed to the filed abit to get the stab level with the wing.It wasnt much but enough to need for it to be done..
The second shot is of a 1litre bottle of car wash to weigh down the high side as the 30minute dryed..
The wing went together with just a ply dieheadral brace and epoxy..There was no holes in the wing for the sero wires to come out so they need to be drilled and for the wing mount, there was no holes in the wing but the mount for it in the fuse was already drilled and blind nutted. So i had to fit the screws to the blind nuts form underneath the mount so they stuck out and mounted the wing and pushed down on the screws to make a dent in the wing so i knew where to drill for it to line up..
