RE: Probond Poly glue for shear webs?
Spar caps are balsa or spruce? If so, it should be OK as the Poly glue will be stronger than the wood.
For most places where you can use yello Wood glue, the poly glues can also be used. I tend to not make that substitution because the poly is messier to work with and more expensive.
