RCU Forums - View Single Post - GOT HIT WITH PROP TODAY!!!
Old 04-27-2004 | 06:06 AM
jettstarblue's Avatar
jettstarblue
Default RE: GOT HIT WITH PROP TODAY!!!
ORIGINAL: Gravityisnotmyfriend
This does lead to a question, what is the best way to shut off a glow engine?
1. Throw a rag into the prop. (not recommended for wood props)
2. Pinch the fuel line to the carb, from BEHIND the prop. (not the best way)
3. The BEST way is to set up the radio, before you ever get the plane to test flying stage, so the carb will close COMPLETELY when the throttle/throttle trim levers are all the way back.
Jetts
