RE: World Spitfire engine choice?
thanks richard, would you suggest to use the origional hardwood mounts or convert to the manufactured engine mounts , in which case do you shim to allow for this , also if we want to install flaps on this model,can we multi task the alerons to this task or would you install seperate flaps , the radio has a heap of available channels jrx10
