RCU Forums - View Single Post - Real Flight Add-ons 4 question
Old 04-27-2004 | 11:00 PM
JVB
Default Real Flight Add-ons 4 question
I have addons Volume 4 and the Edge 540 does not work properly. While flying, if you give it full rudder either way then release it, there is a delay for the plane to respond. It is a noticeable delay. The plane stays crabbed for a bit after the stick is neutralized then kicks back to center. It is the only plane that does this. All others return to neutral flying as soon as the stick is moved to neutral. Anyone else have this problem?
