Go Back  RCU Forums > RC Airplanes > RC Flight Simulator Software
 Real Flight Add-ons 4 question >
RC Flight Simulator Software Discuss rc flight simulator software here. Aerofly Pro, RealFlight G3, XTR, Reflex, etc.
Old 04-27-2004 | 11:00 PM
JVB
Default Real Flight Add-ons 4 question
I have addons Volume 4 and the Edge 540 does not work properly. While flying, if you give it full rudder either way then release it, there is a delay for the plane to respond. It is a noticeable delay. The plane stays crabbed for a bit after the stick is neutralized then kicks back to center. It is the only plane that does this. All others return to neutral flying as soon as the stick is moved to neutral. Anyone else have this problem?
Old 04-28-2004 | 04:26 PM
Default RE: Real Flight Add-ons 4 question
My problem is when I increase the size of the plane it gradually starts to sink into the ground , and on take off emerges like sub-marine, really neat trick. Make sure you get the latest upgrade to have this feature
Old 04-28-2004 | 08:39 PM
JVB,
I had not noticed this problem before (don't fly the edge much) but I have the same symptom. You can visually see the rudder move back to center immediately, but there is a delay before the model responds. It is more noticeable at high speeds. Must have to do wiht the flight model for the Edge.
Carl
