RCU Forums - View Single Post - LANIER EDGE 1.20 CG PROBLEM
Old 04-28-2004 | 10:47 AM
Liv2Fly's Avatar
Liv2Fly
Default RE: LANIER EDGE 1.20 CG PROBLEM
Bruce,
We cut the heads off of the bolts and then epoxied the studs into the wing at the marked locations. I believe you could also secure the bolts to the wing using Gorilla Glue which will expand slightly to fill all the voids. It turned out to be an easy install. Hope this helps.
THANX,
Jeff
