RCU Forums - View Single Post - Is this a good second airplane??!?!
Old 04-28-2004 | 10:53 AM
Fastsky's Avatar
Fastsky
Default RE: Is this a good second airplane??!?!
I have to disagree with the above. Sure the PC9 can fly fast but the important thing is how does it handle at low throttle? A: It does very well and will land almost as slow as your trainer. It also has a trike gear which is the same as your trainer. Best thing is to find an instructor to take it up for the first flight to check the trims and then hopefully be able to stand beside you to offer advise when you take it up. The main thing to remember is that you don't have to fly it at full throttle! Once you take off and get some altitude, throttle back to a bit under 1/2 and just take it easy for a while. The response times will be very fast compared to your trainer but you will quickly get used to this. Then the fun begins![
